Many Organizations have transactions in more than one currency. Such transactions have to be recorded either in the base (home) currency or in the foreign currency. If the transactions are recorded in home currency, the rate at which the foreign currency is exchanged should be recorded as well. At times you need to record the transaction in the foreign currency itself when you maintain the balance of the concerned account in foreign currency.
Tally.ERP 9 uses the term base currency for the currency in which your account books are kept. Foreign Exchange is used interchangeably with foreign currency. The base currency is specified while creating the company.
Tally.ERP 9 makes it easy to manage multiple currencies, automatic calculations of exchange rates, automatic conversion of any currency used to record a transaction to the currency of the account, etc.
The Balance Sheet and Profit & Loss Account of the company is maintained in the base currency. Conversion of foreign currency account balances is done as per rules set by you.
Go to Company Info. > Create Company
Note: At time of installing Tally.ERP 9, if the Country Selection is opted as India/Saarc, the Currency Symbol is defaulted as Rs. in the Company master otherwise if the Country Selection is opted as International (Others), the Currency Symbol is defaulted as £ in the Company master.
More:
'Multi-Currency in Tally.ERP' has been shared with
