With the Export feature of Tally.ERP 9, you can export Tally.ERP 9 data using the available formats. The exported data can be used by other programs. To export the Masters from Tally.ERP 9 execute the following steps:
Go to Gateway of Tally > Display > List of Accounts
In the List of Accounts screen press E : Export.
Select the Language in which you want the data to be exported.
Select a format from the list of Formats available.
Press Enter to accept the default Output Filename. In case you want to save the file in another folder then type the desired path and filename.
Accept to export the Masters to a XML format file.
The exported file is saved in the default Tally.ERP9 folder or the specified folder.
'Export Data from Masters in Tally.ERP 9' has been shared with
