This allows you to configure invoice, delivery notes and sales & purchase orders. The Invoice entry and Order entry screens can be configured for additional information such as export details, shipping details, etc.
Go to Gateway of Tally > F12: Configure > Invoice/Orders Entry
Note: Depending upon the Company Features, options get added in Invoice/order Entry configuration. For instance, if you enable VAT option in F11 Statutory Features, Allow selection of VAT/TAX Class during entry, Warn on Mismatch in VAT Rates and Activate E1 or E2 Transaction option gets added in Invoice/Order entry configuration.
By default, this option is set to YES.
Tally.ERP 9 displays an additional screen to feed in the delivery note details, order details, Terms of payment, party address details, etc., after selecting the required Party ledger account.
By default, Print Default Name & Address of Party is not visible in the Invoice Entry configuration Screen. This option is available only if Accept Supplementary Details in F12 Configure is set to No.
On setting this option to Yes, Tally.ERP 9 Prints the Party Ledger’s Mailing Name and address details given in the Ledger master – in the Invoice. On setting this option to No – the invoice printout will display only the Party Ledger’s Name without address details.
By default, this option is set to No.
If set to Yes – Tally.ERP 9 provides an option to enter consignee Name and address in the Supplementary details screen.
Default order/delivery note entries appearing in the invoice can be changed during invoice entry. Set this to Yes to permit modification of all fields.
By default, this option is set to Yes.
This automates the updation process of the Sales and Purchase accounts for all the items selected in the invoice. In case this option is Set to No – Tally.ERP 9 prompts for sales or purchase accounting allocations after every item.
By default, this option is set to Yes. In this case, Tally.ERP 9 automatically takes the invoice number as the bill reference name and the credit period given in the Party ledger master as the credit period – both as part of the bill-wise details. This enables faster data entry.
Note: In a purchase invoice, Tally.ERP 9 automatically takes the invoice reference number as Bill reference. If invoice reference number is empty then it will take invoice number as Bill reference.
However, if this option is set to No – Tally.ERP 9 prompts the user for bill-wise details at the end of the entry.
If it is set to Yes – Tally.ERP 9 automatically allows you to specify description for each item selected in the invoice.
If it is set to Yes – Tally.ERP 9 automatically allows you to specify the description for each Ledger selected in the Accounting invoice entries.
Note: This options are provided to specify any additional description for sales ledger selected in the Accounting Invoice mode not in the Item invoice mode.
If you want to consolidate the stock items having same rates in Invoice/Challans, set this option to Yes.
Click here for details.
If you want to view the turnover achieved till date with a particular customer, set this option to Yes.
If set to Yes, Tally.ERP 9 provides an option to enter export details for the invoice in the Supplementary details screen.
You can enter the following details:
Place of Receipt
Vessel / Flight No. (the transport used to send the goods)
Port of Loading (from where the goods are despatched)
Port of Discharge (where the goods will be finally offloaded)
Country To (to which country the goods are being sent)
If set to Yes – Tally.ERP 9 allows you to specify Marks details for every item selected in the invoice.
If set to Yes – Tally.ERP 9 allows to you to specify Num. Packages for every item selected in the invoice.
This is similar to the option available in the Voucher Entry Configuration screen. You can configure Tally.ERP 9 to warn in case the item selected reaches a negative balance.
This is similar to the option available in the Voucher Entry Configuration Screen. You can configure Tally.ERP 9 NOT to include expired batches in the list of batches displayed at the time of entry.
This means that in the Sales / Purchase Order and Delivery / Receipt Note entries, you can allocate a sales / Purchase ledger. This enables faster data entry at the time of entering sales / purchase invoices against the Delivery / Receipt notes.
For example:
Name |
Qty |
Rate |
Amount |
Item A |
10 No. |
100 / No. |
1000 |
Item B |
10 No. |
200 / No. |
2000 |
Total Item value |
3000 |
Discount |
-10% |
-300 |
If you add another line, Tax 1%, it will calculate 1% on 3000 (on Total Item value) giving 30 as Tax value. However, if you opt for calculating on the current sub-total, Tax value will be calculated on 2700 [3000-300] giving 27 as Tax value.
'Invoice / Orders Entry' has been shared with
