Payroll is a default feature available in Tally.ERP 9. Enabling Payroll is a two step simple process:
To enable Payroll Feature in Tally.ERP 9, follow the steps given below:
Go to Gateway of Tally > F11: Features > F1: Accounting Features
Tab down to Cost/Profit Centres Management section
Set Maintain Payroll to Yes
You can set More than ONE Payroll / Cost Category to Yes to allocate Employee Cost, by creating separate Employee Categories
Press Enter to accept and save
Note: You can enable More Than ONE Payroll / Cost Category option to Yes, where parallel allocation of Employee Cost / Cost Centre is required.
Once the Payroll feature is enabled by the user, the Gateway of Tally screen will appear as shown:
More:
'Enabling Payroll in Tally.ERP 9' has been shared with
