https://help.tallysolutions.com/docs/te9rel49/Job_Work/Job_Worker_and_Principal_Manufacturers_Ledgers.htm
Job Worker and Principal Manufacturers Ledgers
Job Workers (Sundry Creditors) are those to whom the Job is delegated. Principal Manufacturers (Sundry Debtors) are those from whom the job is received for Job Work.
Job Worker Ledger
ABC Company delegates the job to the following Job workers
To Create Job Worker Ledger
Go to Gateway of Tally > Accounts Info> Ledgers > Create
  • Name: In this field mention the Job Worker’s name. E.g. Mega Manufacturers
  • Under: In this field select the group under which the Job Worker ledger to be grouped. E.g. Sundry Creditors
  • Maintain balances bill-by-bill: Set this option to Yes to maintain the Job Worker payment balances bill -by -bill.
  • Enter the Mailing Details and Tax Information
The completed Job Worker ledger is displayed as shown
  • Press Enter to save.
Create the below Job Worker ledger as per the details provided
Job Worker
Under
National Manufacturers
Sundry Creditors
Yes
Principal Manufacturer Ledger
ABC Company takes Job work form the following Principal Manufacturer
To Create Principal Manufacturer Ledger
  • Name: In this field mention the Principal Manufacturer’s name. E.g. Bright Home Appliances
  • Under: In this field select the group under which the Principal Manufacturer ledger to be grouped. E.g. Sundry Creditors
  • Maintain balances bill-by-bill: Set this option to Yes to maintain the Principal Manufacturer payment balances bill -by -bill.
The completed Principal Manufacturer ledger is displayed as shown
