When a TDS Bill is marked by the user as External Clarification in order to get the required information from the Client, it will be listed under External Clarification column in the Tax Audit Dashboard.
The drill down and other options for the TDS External Clarification Summary is similar to the TDS Re-Audit Summary report. For details, refer to TDS Re-Audit Summary.
'TDS Need Clarification Summary' has been shared with
