This screen allows you to configure the Receipt Note for printing. The Print Configuration settings shown below is applicable to receipt note voucher type only.
Note: The options of the above Receipt Note Printing Configuration screen are the default settings.
By default, Title of Receipt Note will be displayed as Receipt Note. However, you can change the Title as per your requirement.
Note: You can also set the Title for Optional Receipt Note.
By default, sub-title of purchase invoice is set as blank. However, you can set the sub title as per your requirement.
Page setup contains Height, width, Top margin and left margin. By default, Height is set as 10 inch, width is set as 7.50 inch, Top margin is set as 0.25 inch and Left margin is set as 0.50 inch.
Some of the configurations are already explained in the Purchase Voucher configuration.
'Receipt Note' has been shared with
