https://help.tallysolutions.com/docs/te9rel49/Data_Management/Inward_Connectivity.htm
Inward Connectivity
Inward connectivity integrates data from other systems with Tally.ERP 9. With this feature you can use data from other systems in Tally.ERP 9 by creating an integrated system.
For example, a customer contact management program containing details like status of an order and last contact made can be brought into Tally.ERP 9 and merged into a report containing outstanding balances. Changes made to the data are immediately reflected in Tally.ERP 9.
To connect to other programs and use external data in Tally.ERP 9, you can contact the nearest Tally Offices or send an email to support@tallysolutions.com.
