https://help.tallysolutions.com/docs/te9rel49/Job_Work/Stock_Items_Raw_Materials.htm
Stock Items - Raw Materials
To create the stock item
Go to Gateway of Tally > Stock Items > Create
  • In Name field enter the stock item Name. E.g. Bottom Plate-12Ltr
  • Group the Stock item Under the Stock Group RM - Cooker (if Stock group is not created use Alt + C from Under field to create the stock group)
  • In Units field select the applicable unit of measurement. E.g. Nos
  • Set the option Enable Cost Tracking to No
The completed Stock Item Creation screen appears as shown
  • Press Enter to save
Similarly create the below Raw Materials as per the details
Stock Items
Under
Unit
Lid Alluminium Plate-12 Ltr
RM - Cooker
Nos
Handle (12 Ltr)
RM - Cooker
Nos
Packing Box (12 Ltr)
RM - Cooker
Nos
Hand Book
RM - Cooker
Nos
Bottom Plate-10Ltr (0.23 mm)
RM - Cooker
Nos
Bottom Plate-10 Ltr (0.17 mm)
RM - Cooker
Nos
Lid Alluminium Plate-10 Ltr
RM - Cooker
Nos
Handle (10 Ltr)
RM - Cooker
Nos
Packing Box (10 Ltr)
RM - Cooker
Nos
Raw Materials - If Excise Applicable
Go to Gateway of Tally > Inventory Info. > Stock Items > Create
  • Enter the Stock Item Name, Group, Unit, Tariff Classification and enable Set/Alter Excise Details to Yes
  • In Excise Details screen select Reporting UOM, enable Set/Alter Duty Details to select the duties applicable for the stock item and select the Stock Item Type- Principal Inputs.
  • Press Enter to save.
Similarly, create all the Raw Materials if Excise is applicable
