https://help.tallysolutions.com/docs/te9rel49/Payroll/employee_vouchers.htm
Employee Vouchers
To view the Employee Vouchers,
Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary
Or
Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary
  • Press Enter on the required Pay Head Type
  • Press Enter on the required Employee Name
  • Press Alt+F1 key or click the button F1: Detailed
The user can drill down to a corresponding Payroll/Payment Vouchers from the above report.
