Statutory Audit feature in Tally.ERP 9 enables the Auditor to analyse the Company Data using the Data Analysis tools available to form an opinion as to the true and fair view of accounts by highlighting the exceptions. The tools helps in comparing the Company data spread across two financial years in the same Company or in a different (Split) Company.
Tally.ERP 9 provides the following tools for Data Analysis:
The Auditor can analyse the Company data using the above tools and then Audit the Vouchers from the Auditing section through the following features:
The Auditor can also apply Sampling Method wherever required to audit only relevant Vouchers.
The Statutory Audit tool will also help in generating the Financial Statements listed below:
Note: For simplification of understanding the following terminology will be used for Statutory Audit:
Audit Year - Year for which Audit is happening. This can also be referred as the Current Period.
Previous Year - Year prior to the Audit Year.
e.g. if Audit is happening for 2008-2009 then 2007-2008 will be Previous Year.
In addition to the above, Tally.ERP 9 also provides the facility to create the Audit Programme consisting of detailed checklist with other required details.
'Statutory Audit in Tally.ERP 9' has been shared with
