https://help.tallysolutions.com/docs/te9rel49/Job_Work/JI_Orders.htm
Orders
Job Order Summary report displays the summary of all the Job work In orders which are outstanding (job order in raised on Principal Manufacturer towards which the raw materials are pending to receive)
To view Job Order Summary report
Go to Gateway of Tally > Display > Job Work In Reports > Order Outstandings > Orders
Job Order Summary report displays the details of stock item for which the Job order is pending along with the details of Ordered Quantity and Balance Quantity
Job Order Details
To view the Job Order Details select the item and press enter.
