To create Packing Charges Ledger,
Enter the Name of the ledger.
Select Direct/Indirect Expenses as the group name in the Under field.
The option Inventory values are affected is set to No by default.
Set the Type of Ledger field to Not Applicable.
Set the option Used in VAT Returns to No as the ledger is an additional ledger and not being used in lieu of purchase ledger.
Set the option Use for Assessable Value Calculation to Yes. On enabling this option, the additional fields - Apportion for and Method of Apportion will be displayed. The value entered for this ledger while recording entries will be apportioned to the assessable value as per the method selected for apportionment.
In the Apportion for field select VAT and set the Method of Apportion to Based on Value.
Press Y or Enter to accept and save.
'Packing Charges' has been shared with
