Customs Clearance Register is an import bill-wise report displaying the details of import of excisable goods having stock pending for clearance.
This report displays the information of goods imported, cleared from customs warehouse and pending for clearance.
To view Customs Clearance Register,
Go to Gateway of Tally>Display>Statutory Reports>Excise Reports>Dealer/Importer>Excise Registers>Customs Clearance Register
The Customs Clearance Register can be viewed for All Items or One Item.
To view Customs Clearance Register for all items, select All Items and press Enter
In Select Excise Unit screen, select the Excise Unit in the option Name of Excise UnitThe Customs Clearance Register appears as shown below:
To view the Customs Clearance Register for one item, select One Item and press Enter.
In the Select Excise Unit screen, select the Excise Unit, tariff classification and the excise stock item to generate Customs Clearance Register for one item.
'Customs Clearance Register' has been shared with
