Go to Gateway of Tally > Display > Statements of Inventory > Reorder Status
Select a Group of Stock Items from the List of Groups.
The Inventory Reorder Status screen displays.
This report gives you the reorder status of Stock Items grouped under the selected Stock Group. When Primary group is selected in Items Under field, the report displays Reorder Status of all the Stock Items.
Click the button A: Reorder Only to remove those items for which there are no orders to be placed For instance, In the above screen, Item C does not have any quantity for Reorder status and hence you may select A: Reorder Only to eliminate the same from the list.
The above report besides indicating the quantity to be ordered, also allows drill down from the fields for more information.
Press Enter on this field for information on suppliers of this Stock Item and the details of their previous supplies.
Drill down for Item Monthly Summary (Inwards and Outwards) and other details.
Press Enter on this field for details on the pending purchase orders.
Drill down to know the details on the sales orders, which are due i.e., free stock available for sale.
Drill down by pressing Enter to display the Reorder Level Specification screen for the Stock Item.
Tally.ERP 9 calculates this value based on the Nett Available Stock and Re-Order Level.
Tally.ERP 9 calculates this value based on the re-order definition.
'Reorder Status and Quantities to Order' has been shared with
