The Tally.ERP 9 gives various options to make the CST feature, simple and user friendly. It provides various reports as required by the statute and also gives proper records for dealer’s reference. The following are some of the main features of CST in Tally.ERP 9:
Quick, easy to setup and use.
Flexibility in selection of forms and form numbers during voucher entry or at the time of report generation.
Party-wise and Form-wise report generation capability on Forms Issuable/ receivable.
Sorting by Name of the party in group wise Forms Issuable/receivable report
Auto-fill option in the Forms Receivables/ Issueables feature that prevents error-prone and fast data entry.
Instant generation of State Specific CST Returns after completion of data entry for the return period.
'CST Features in Tally.ERP9' has been shared with
