When a Voucher is marked by the user as Internal Observation, it will be listed Internal Observation column in the Tax Audit Dashboard. The user may mark a Voucher as Internal Observation, due to one of the following reasons:
Want to show the Voucher to his senior to form the opinion
Has seen the Voucher and reserved the Audit comments due to some reason
The TCS Internal Observation Summary report contains the TCS Bills and TCS Payment Vouchers which are marked as Internal Observation. The drill down and other options for the TCS Under Observation Summary is similar to the TCS Re-Audit Summary report. For details, refer to TCS Re-Audit Summary.
'TCS Under Observation Summary' has been shared with
