The pending goods to be delivered can be tracked using the CT-3 numbers provided while recording sales orders received from EoUs.
To view the pending orders,
Go to Display > Statutory Reports > Excise Reports > Manufacturer > Export Register > CT-3 Outstandings
Select the Excise Unit, party ledger, and CT -3 number. You can select Any if you want to view all outstanding CT-3 orders for the selected party
The CT-3 Pending Report will be displayed for the selected party:
The report displays the date of order, order number, name of the item, CT-3 number and date of issue of the CT-3, ordered quantity, quantity supplied, and quantity that remains to be supplied.
It also displays the number and date of the Form AR.E. 3 issued.
The following F12: Configure options can be used to modify the view of the report:
Show Pre-Closure Quantity: If the quantity ordered has been pre-closed by the party, setting this option to Yes will display the quantity pre-closed
Show Outstanding Sales Bills: Enabling this option will display the sales bills pending to be raised for the selected EoU
Show Cleared Sales Bills: Enabling this option will display the sales bills that have been raised for the selected EoU
'CT-3 Outstandings' has been shared with
