To create a Bonus Pay Head,
Go to Gateway of Tally > Payroll Info. > Pay Heads > Create
Enter Pay Head name in the Name field
Select Bonus as the Pay Head Type from the list of Pay Head Type
Select the Income Type for the Pay Head
Select Indirect Expenses from the List of Groups in the Under field
By default, Affect Net Salary is set to Yes. Type No, if you do not want this component to be included in the Pay Slip
By default, the Pay Head component name entered in the Name field will appear in the Pay Slip, if you want to change the default Pay Head component name then alter it in Name to appear in Payslip field
By default, Use for Gratuity is set to No
In the Income Tax Details screen,
Select Other Earnings/Allowances (Fully Taxable) as the Income Tax Component
In Tax Calculation Basis select On Actual Value for User Defined Pay Heads as the amount will be different in each month so the Tax should be rationalised accordingly and spread across the remaining period. If value of pay head is fixed in nature then select On Projected Value
Set Deduct TDS across Period(s) to Yes to deduct Tax across the remaining period. If set to No, entire tax will be deducted in the same month
Set Exclude for ESI Eligibility to Yes, if you want to this Pay Head to be considered for ESI Calculation but not for ESI Eligibility.
In the Calculation Type field select As User Defined Value from the List of Calculation.
Press Enter to accept.
'Creating a Bonus Pay Head (Payroll)' has been shared with
