https://help.tallysolutions.com/docs/te9rel49/Job_Work/Jo_Stock_Ageing_Analysis.htm
Ageing Analysis
Ageing Analysis report displays the details of period (i.e. for how long) stock is lying with the Job worker.
To view the stock Ageing Analysis reports
Go to Gateway of Tally > Display > Job Work Out Reports > Stock > Ageing Analysis
  • In Select Item screen select the stock group foe which the Ageing Analysis report to be viewed
The Stock Ageing Analysis report is displayed as shown
