Β
As per Excise Rules, if the Job Worker is registered under excise he has to maintain Annexure - V to record the Material Movement. In Tally.ERP 9 Annexure - V can be generated when the Excise for Manufacturer feature is enable in F11: Features.
To generate Annexure - V
Go to Gateway of Tally > Display > Job Work In Reports > Job Work Registers > Annexure - V
In Select Item screen select the Excise Unit for which the Annexure - V Β to be generated
The Annexure - V is displayed as shown
For column description refer the topic Material Movement Register
Β
'Annexure - V (Job Work In Reports)' has been shared with
