You can work with Arabic numerals by making the following settings in the Control Panel:
Start Control Panel
Click Clock Language and Region
Click Region and Language
In the Region and Language window set the Format to Arabic
Click Additional Settings
In the Customize Format set Use Native Digits to National
You can now start Tally.ERP 9 and record a transaction in Arabic with Arabic numerals.
'Working with Arabic Numerals' has been shared with
