To view the order position in Stock Summary,
Go to Gateway of Tally > Stock Summary
Press Alt + F1 (For detailed view)
Press Alt + N > Select Orders & Stock Details
Orders & Stock Details screen is displayed as shown.
Or
In the Stock Summary screen, you can add a new column using Alt + C.
Sales Order Reports can be accessed through Alt + F7 or Alt + C of the Stock Summary.
Go to Gateway of Tally > Stock Summary > Press F9 > select Purchase or Sales Order
Note: Inventory Reports and Accounting Reports can also be accessed through ALL other reports by pressing F9 or F10 (Accounting/ Inventory Reports).
'Viewing Order Position' has been shared with
