https://help.tallysolutions.com/docs/te9rel49/04_ADVANCED_FEATURES_IN_TALLY/01_Advanced_Accounting_Features_in_Tally/01_Cost_Categories_and_Cost_Centres/Altering_a_Cost_Centre.htm
Altering a Cost Centre
To alter an existing Cost Centre
Go to Gateway of Tally> Accounts Info.> Cost Centres> Alter (under Single Cost Centre)
The Cost Centre Alteration displays,
Make the necessary changes and Accept to save.
Deleting a Cost Centre
You can delete a Cost Centre from the Cost Centre Alteration screen by pressing ALT+D.
You can delete a Cost Centre only if
  • It does not have any Cost Centres created under it.
  • It is not used in any transactions.
Explanation of Buttons for Cost Centres in Single Mode
Groups, Ledgers, Voucher Types
It enables you to switch to these areas without having to quit from the current screen.
F11: Features
To change company features. For more information refer  F11: Features in Tally.ERP 9.
F12: Configure
To change the configuration of master information. For more information refer F12: Configurations in Tally.ERP 9.
Note: F12: Configuration changes affect all companies in the data directory, whereas F11: Features changes affect the current company only.
