https://help.tallysolutions.com/docs/te9rel49/Indonesia/Credit_Note_for_VAT_Indonesia.htm
Creating a Credit Note
A Credit Note voucher is used to record Sales Return entry.
To create a Sales Return entry,
In F11: Features > F1: Accounting Features, set Use Invoice mode for Credit Notes to Yes
Go to Gateway of Tally > Accounting Vouchers > Ctrl + F8: Credit Note
  1. Enter the Reference number in the Ref field if required
  2. Select Party’s A/c Name, for e.g., Supreme Traders from the List of Ledger Accounts
  3. Enter the required details in Party Details sub form
  4. Select the ledger Sales @ 10% in the Sales Ledger field
  5. Select the VAT/Tax Class from the List of Ledger Accounts
  6. Select the required stock item, for e.g., Monitors from the List of Items
  7. Select the ledger Output VAT @ 10% from the List of Ledger Accounts
  8. Enter Narration if required
