Stock transfer happens in the following two scenarios:
Closing stock lying in the dealer unit on 31st March 2014 upto the date of registration as Importer, has to be transferred to importer unit as opening stock using voucher class created for stock transfer in stock journal voucher
From the books beginning date with dealer registration till the date of registration as Importer, the complete stock has to be transferred to importer unit
If goods are purchased to importer unit, the stock journal voucher class need not be used.
In the closing stock of goods lying in dealer unit, the goods invoiced with Nature of Purchase as Importer can be transferred to importer unit as opening stock by:
Manually recording the voucher
Using the Import Helper button
Consider the example of the dealer unit obtaining importer registration on 1st May 2014. Stocks in dealer unit purchased as imports have to be transferred to importer unit using stock journal voucher class.
To record the transaction for stock transfer,
Go to Gateway of Tally > Inventory Vouchers > Press Alt+F7 for Stock Journal > select the Voucher Class created for transferring stock to importer unit
The dealer unit gets displayed as the Excise Unit
In the Destination Godown field, select the godown created with the Registration Type, Importer
In Supplier Details screen, the List of Purchases gets displayed for selection
Select the required purchase transaction
Note: Quantity Utilized shall be the complete pending quantity pertaining to the purchase reference selected and the same cannot be edited
The completed Stock Journal voucher appears as shown below:
Press Enter to accept
Note1:
1. If the quantity entered is more than the stock available in dealer’s unit, an error message gets displayed. Only after entering the quantity which is equal to available stock, the voucher gets saved. Occurrence of this error is possible only during manual voucher entry.
Go to Gateway of Tally > Inventory Vouchers > Press Alt+F7 for Stock Journal > Select the Voucher Class created for transferring stock to importer unit
Click I: Import Helper button to automate the stock transfer transaction
In the Import Helper screen,
Select the Destination Unit from the List of Godowns
In From date field, the books beginning date gets displayed which can be changed if required. Purchases recorded from this date gets considered for stock transfer
In To date field, the transaction/stock journal voucher date gets displayed. On changing this date, the voucher date also gets changed
The completed Import Helper screen appears as shown below:
Based on the information provided in the Import Helper screen, the closing stock of all the items purchased by selecting the Nature of Purchase as Importer prior to the date of registration as Importer, gets transferred to the destination godown.
Note: When Excise Purchase transaction is marked ‘Yes’ for Customs Clearance Pending and when no stock is received such transactions shall not form part of stock Transfer. However, after paying the customs duty the stock can be received in Dealer Unit and later a stock transfer can be initiated if required.
The Supplier Details screen appears as shown below:
Press Enter to accept the Supplier Details screen and the Inventory Voucher Creation screen will appear as shown below:
'Stock Transfer' has been shared with
