https://help.tallysolutions.com/docs/te9rel49/04_ADVANCED_FEATURES_IN_TALLY/01_Advanced_Accounting_Features_in_Tally/Budgets/Altering_a_Budget.htm
Altering a Budget
You can modify a budget, using the alter option.
Go to Gateway of Tally > Accounts Info > Budgets > Alter
  1. In the Budget Alteration screen, modify the fields as required. Change the period or change budgets of Groups, Ledgers and Cost Centres.
Note: By default, Set/Alter Budgets is set to No. Set this option to Yes to alter.
Deleting a Budget
To delete a budget:
  • Press Alt+D.
