As per the Notification dated 28thFebruary 2014, with effect from 1st April 2014, all businesses registered as dealers of both imports and indigenous excisable goods have to:
Obtain a fresh registration as importer
Transfer the closing stock lying in dealer excise units as on 31st March 2014 to importer excise units, to be sold as opening stock under the fresh registration as importer
Maintain separate books of accounts
Generate e-returns with importer registration
To support the requirements of this Notification, the Excise for Importer feature is introduced with the facility to:
Provide registration details of importer
Create godowns with Excise Registration Type as Importer
Transfer stock to importer unit, either manually or using the Import Helperbutton
Record excise invoices
Generate the following reports:
Excise Stock Journal
Excise Purchase Bill Register
Excise Stock CENVAT Register for One Item and All Items
Customs Clearance Register
Extract reports
Form RG 23D
Generate e-returns
'Excise for Importers' has been shared with
