Pay Head Configuration screen allows the user to configure the Income Tax Components for all the existing Pay Heads. The Ledgers which are used for making the Payroll payments also can be configured for the respective Income Tax Component.
Go to Gateway of Tally > Payroll Info. > Income Tax Details > Pay Head Configuration
Those Pay Heads which are already configured for the Income Tax will be shown in bold. The Pay Heads which are not configured are shown in Italics.
Note: The EPF A/c No. 1 and Professional Tax are also configured internally.
Press Enter on any of the Pay Heads to configure/re-configure the same for Income Tax
In the Income Tax Configuration screen,
Name of Pay Head / Ledger : Pay Head / Ledger name is defaulted
Master Type: Displays whether its a Pay Head or a Ledger for easy identification of user
Income Tax Component: Select the required Income Tax Component for correct Tax Computation from the List of Income Tax Components
Tax Calculation Basis: Select the appropriate Tax Calculation Basis from On Projection and On Actuals
On Projection: Will take the Pay Head/Ledger Value from Salary Details or from Voucher ( in case of User Defined pay head) and the same will get projected for remaining period.
On Actuals: Will take the Pay Head Value (latest) and the same will get projected for the remaining months also.
Deduct TDS Across Period(s): Set this option to No, to Deduct entire TDS in the same month. Set it to Yes to spread the TDS Deduction across the remaining period.
Press Enter to Accept
Similarly, all other Pay Heads can also be configured for Income Tax.
Click on A: Add Ledger or press Alt+A to select and Configure any Ledger for Income Tax. The Ledger which are used for making payments to employees can be considered for Income Tax using this option.
Example, Conveyance can be paid as an expense also by the Employer using an accounting entry. To compute the Income Tax, it will be important for the Employer to configure Conveyance Ledger for Income Tax.
Press Enter to accept and save
Once, the Ledger is configured for the Income Tax, it will appear in the Pay Head / Ledger Configuration screen as shown:
Click on T: Tax Config. or press Alt+T, to view the Tax Configuration screen.
'Configuring Income Tax Components - Pay Head Configuration (Payroll)' has been shared with
