https://help.tallysolutions.com/docs/te9rel49/06_PRINTING_REPORTS/Multi_Part_Printing.htm
Multi-Part Printing
Multi-Part printing is the concept introduced in Tally.ERP 9 which splits the entire printable into parts when the line does not fit the specified page width. Each part is identified with an alphabet and associated to the respective page number. Each page can have parts commencing with the alphabet A and ending with Z, in case the number of parts for a page are exceeding the alphabet Z, the fresh parts commence with a combination of alphabets AA, AB, AC……AZ, BA, BB, BC…..BZ and so on.
Print Sequence
Printing a report with multiple parts commences by printing all the pages for part A, , i.e., 1A, 2A, 3A, 4A, …….nA, followed by printing all the pages for part B and then prints all pages for part C and so on.  The diagram below depicts the multi-part printing sequence:
To print specific parts of the report, select the required report that you want to print
  • Click P: Print or press Alt+P
  • Click G: Page Nos or press Ctrl+G
The Page Range to Print screen appears
  • By default the Page Numbering start from field is set to 1
  • In the Page Range field enter the required page numbers or parts to be printed.  E.g.: 1B to All to print all pages and parts commencing from 1B (1B……nB, 1c….nC,……….) where n is the ending page number.
Keyword
Example
Details
All / Every
All Pages
Every Pages
E.g.: All Pages
E.g.: Every Pages
Prints all the pages in a report
Pages Numbered / Pages Numbers
Pages Numbered 9,9,9
Page Numbers
Pages Numbered 1,2,5
Page Numbers 1,2,5
Prints all the parts for specified page numbers
Pages Numbered 9 and 9
Page Numbers 9 and 9
Pages Numbered 1 and 7
Page Numbers 5 and 7
Prints all the parts for specified page numbers only
Pages Numbered 9Z, 9Z and 9Z
Pages Numbered 4A, 6A and 7B
Prints the parts for specified page numbers only
Pages Numbered 9Z to 9Z
Pages Numbered 7C to 12G
Prints from the specified part of the page to the specified part of the page.
Pages Numbered 9Z, 9Z to 9Z, 9
Pages Numbered 1A, 3B to 5C, 8
Prints from the specified part of the pages to the specified part of the pages and all parts for the page specified.
Pages Numbered 9, 9 to 9 and 9
Pages Numbered 1, 3 to 5 and 7
Prints all parts of the specified pages
Also use…..
Part
Part, Part, Part…….
A
A,B, C
Print all the pages available for the specified part
Page No Part – Page No Part
Page No Part to Page No Part
1A - 3C
3G to 5D
Print all the pages and parts specified
Page No Part, Page No Part, Page No Part
1A, 5B, 7C
Print the specified page numbers and parts
Exclude/Excluding/Except/Without/Not
Pages Numbered 9 to 9, exclude 9Z
Pages Numbered 3 to 5, exclude 2H
Prints all parts for specified pages excluding the specified part
Pages Numbered 9, 9 to 9, 9, except 9Z
Pages Numbered 1 to 3, 5, except 2H
Pages Numbered 9, 9 without 9Z
Pages Numbered 1 to 3, 5, without 2H
Pages Numbered 9, 9 to 9 not 9Z
Pages Numbered 1 to 3 not 2H
All pages excluding 9, 9Z
All Pages excluding 2, 5A
Every pages excluding 9, 9Z
Every Pages excluding 2, 3C
Also use…..
Page No Part – Page No Part exclude Page No Part
Eg.1: 1A - 3C exclude 1B
Eg.2: 1A - 3C except 1B
Print the specified page numbers and parts except/excluding the specified page number and part
Even / Back
Even
Back
Eg.1: Even
Eg.2: Back
Print all even pages
Even, Page No Part
Even, 3D
Even, 7
Prints all even pages and the specified page
Even, exclude Page no Part
Prints all even pages excluding the specified page
Even from Page Number
Even from 6
Prints all even pages from the specified page
Odd / Front
Odd
Front
Eg.1: Odd
Eg.2: Front
Print all odd pages
Odd, Page No Part
Eg.1: Odd, 2
Prints all odd pages including the specified page & part
Odd, exclude page no part
Eg.1: Odd, exclude 3C
Prints all odd pages excluding the specified page & part
Odd from Page Number
Odd from 5
Prints all even pages from the specified page number
To/Upto/Uptill/Till
Upto Page No/Part
Eg.1: Upto 5
Eg.2: Upto 3A
Prints from the first page till the specified page / part
Till Page No/Part
Eg.1: Till 2C
Eg.2: Till 5
To Page No/Part
Eg.1: To 4C
Eg.2: To 7
Uptill Page No/Part
Eg.1: Uptill 5
Eg.2: Uptill 3A
To/Upto/Till/Uptill 9, excluding 9Z
Eg.1: To 3, excluding 3C
Eg.2: Upto 5, excluding 1D
Eg.3: Till 2, excluding 1C
Eg.4: Uptill 4, excluding 4G
Prints all the pages from the first page till the specified page / part excluding the specified page number / part
From
From Part / Page No
Eg.1: From 2
Eg.2: From 3D
Eg.3: From 2 to 5
Prints all pages from the specified page and part number to the end of the report
From Part / Page No excluding 9Z
Eg.1: From 2 excluding 3c
Prints all pages excluding the specified page number to the end of the report
Beg/Beginning/Starting/First/Initial
Beg Page No / Part
Eg.1: Beg 1
Eg.2: Beg 2C
Eg.3: Beg 3 to 7
Commences printing from the specified page / part to the specified page / part
Beginning Page No / Part
Eg.1: Beginning 1
Eg.2: Beginning 2C
Eg.3: Beginning 3 to 7
Starting Page No / Part
Eg.1: Starting 1
Eg.2: Starting 2C
Eg.3: Starting 3 to 7
First to 9
Eg.1: First to 5
Eg.2: First to 2C
First to 9
Eg.1: First to 5
Eg.2: First to 2C
Print the specified pages from the first page
Initial to 9
Eg.1: Initial to 2
Eg.2: Initial to 1C
Eg.3: Initial to end
Beg/Beginning/Starting/First/Initial excluding 9Z
Eg.1: Beg 1 excluding 1C
Eg.2: Beginning 2 excluding 4A
Eg.3: Starting 1 excluding 3B
Eg.4: First to 5, excluding 2B
Eg.5: Initial to 5, excluding 1C
Eg.6: Beginning to end excluding 3S
Print all the pages from the first page excluding the specified page no/part
End/Ending/Last/Final
Part/Page No to End
Eg.1: 1D to End
Eg.2: 3 to End
Eg.3: Starting to End
Commences printing from the specified part/page no till the end of the report.
Part/Page No to Ending
Eg.1: 2F to Ending
Eg.2: 5 to Ending
Eg.3: Starting to Ending
Part/Page No to Last
Eg.1: 2F to last
Eg.2: 5 to last
Eg.3: Starting to last
Part/Page No to Final
Eg.1: 4C to Final
Eg.2: 2 to Final
Eg.3: Starting to Final
End/Ending/Last/Final exclude 9Z
Eg.1: 1D to End, excluding 2
Eg.2: 5 to Ending, excluding 7
Eg.3: Starting to last excluding 5D, 6
Eg.3: Starting to Final excluding 3G, 7
Commences printing from the specified part/page no till the end of the report excluding the specified page no/part.
