https://help.tallysolutions.com/docs/te9rel49/05_REPORTS/Management_Information_System_(MIS)_Reports/06_Display_Fund_Flow_Statement/Fund_Flow_in_TallyERP.htm
Fund Flow in Tally.ERP 9
To view Funds Flow
Go to Gateway of Tally > Display > Cash/Funds Flow > Funds Flow
  1. Press ALT+F2, change period - From: 1-04-2008 to 31-8-2008.
The funds flow statement is displayed as shown.
  1. A Monthly Funds Flow Summary with the movement of working capital for each month is displayed. It shows the Opening and Closing Balances of each month with a column for Funds Flow.
  2. Select a month and press Enter to drill down.
  3. Select F1: Detailed to see the funds flow for the selected month.
