https://help.tallysolutions.com/docs/te9rel49/Job_Work/JI_Order_Outstandings.htm
Order Outstandings
Order Outstandings report display the details of all the Job work In orders raised on the Principal Manufacturer which are pending.
To view the Order Outstandings report
Go to Gateway of Tally > Display > Job Work In Reports > Order Outstandings
The Order Outstandings reports are
