When a Voucher is marked by the user as External Clarification in order to get the required information from the Client, it will be listed under External Clarification column in the Tax Audit Dashboard.
External Clarification column is divided into:
To view the report of the External Clarification Ledger Vouchers for Loans/Deposits Accepted,
Go to Gateway of Tally > Audit & Compliance > 44AB Audit
Highlight the numbers in the External Clarification - Pending column of Loans / Deposits Accepted
Press Enter to view the Ledger Vouchers that are marked as External Clarification by the user.
The various fields and button options in the above screen are similar to Ledger Vouchers report.
To view the report of the External Clarification - Clarified Ledger Vouchers for Loans / Deposits Accepted,
Highlight the numbers in the External Clarification Clarified column of Loans / Deposits Accepted,
To Audit the Under Observation Vouchers, refer to the Auditing of Loans/Deposits Accepted & repaid.
'Need Clarification Ledger Vouchers for Loans & Deposits Accepted' has been shared with
