This enables you to set the number styles. The default styles and symbols are specified. However, you have the option of changing them in the respective fields according to your preference.
For example, change negative sign from (-) to (+).
Go to Gateway of Tally > F12: Configure > Numeric Symbols
Note: If you change any configuration of Number Styles, you need to restart the application for those changes to take effect.
'Numeric Symbols' has been shared with
