https://help.tallysolutions.com/docs/te9rel49/Data_Management/Tally_ODBC.htm
Tally ODBC
With Open Database Connectivity you can dynamically exchange data between Tally.ERP 9 and any other application dynamically.
You must ensure that MS-Query is installed on the computer in which you will be installing Tally.ERP 9. This enables ODBC as soon as Tally.ERP 9 is installed.
The ODBC server is displayed on the information block of the information pane.
To read more on the inward and outward connectivity click on one of the corresponding links below:
