The Operating System Keyboard is used by those who know to read and write in the language of their choice. Entering data in Tally.ERP 9 using the Operating System Keyboard is different from using the phonetic keyboard as the keyboard layout differs.
To configure the Keyboard for an Operating System Keyboard,
Click K: Keyboard from the horizontal toolbar or press ALT + K
In Keyboard Configuration screen, select Hindi Traditional (System) from the List of Languages
Note: The Languages displayed in the List of Languages for Keyboard Configuration depends upon Operating System.
The On-Screen keyboard is a virtual keyboard which displays on the computer screen. Using the On-Screen keyboard will familiarise you with the Operating System keyboard’s layout.
Configuring On-Screen Keyboard
Go to Start > Programs > Accessories > Accessibility
Select Onscreen Keyboard
The On-Screen Keyboard will appear as shown below.
Use Alt + Shift to configure the language of choice. For example, if you wish to enter data in Hindi, select Hindi using Alt + Shift or select the same from the Language bar as shown.
The On-Screen Keyboard will appear in Hindi as shown, as you place the cursor on it.
'Using Operating System Keyboard' has been shared with
