The Periodic Payments and Receipts provides the list of recurring Ledger Vouchers based on the Ledgers identified by the Auditors. This report also provides the comparison of Ledgers Vouchers with previous years Vouchers to analyze the deviations if any.
To view the Periodic Payments and Receipts,
Go Gateway of Tally > Audit & Compliance > Audit & Analysis > Period Payments and Receipts
The report provides the details of total amount spent or received along with the total number of Vouchers during each year. It also provides the details of the Amount and Voucher variance which can be used to carry on the further investigations.
Click on F4: Group or press F4 to filter the Periodic Payments and Receipts belonging to the selected Group.
Place the cursor on the required Ledger and click on F8: Show Ledger or press F8 to view the Ledger Vouchers report for that Ledger.
Click on Ctrl+F9: Master Config or press Ctrl+F9 keys to identify the parties as MSME, Related Parties, Periodic Ledgers and apply Sampling methods for Auditing.
W: Working Note
Click on W: Working Note or press Alt+W keys to specify the working note details at Company or Group or Ledger level. The details provided in working note will be captured in Audit Working Paper along with the details of User Name, Working Note Date & Time, Status, Note etc.
Click on F9: Inv Reports or press F9 key to navigate to the default Inventory Reports like Godown Summary, Movement Analysis, Stock Summary etc.
Click on F10: Acc Reports or press F10 key to navigate to the default Accounting Reports like Balance Sheet, Cash Flow, Trial Balance etc.
Click on F10: Audit Reports or press Alt+F10 keys to navigate to the other Audit Reports within Statutory Audit and 44AB Audit (Tax Audit).
Click on F12: Configure or press F12 to change the default display for the above report.
Show Name of Group: Set this option to No to hide the name of the immediate Group/Subgroup
Show ledgers with Variance: User can choose to view only those Ledgers that fulfill
Variance Type: The user can choose to view the variance based on amounts, or percentages
Range:The user can choose to view Ledgers with variance equal to, greater than, or lesser than a specific value:
The value has to be specified in the next field:
Appearance of Names: Select the required Display Name for the Periodic Ledgers
Scale Factor for Values: Select the required scale factor from the list to display the amount in the respective denomination.
The Auditor can press Enter on any of the Ledgers to view the Periodic Ledger Monthly Summary report.
'Periodic Payments and Receipts (Audit and Compliance)' has been shared with
