To view Cash Flow:
1. Go to Gateway of Tally > Display > Cash/Funds Flow > Cash Flow
2. Press ALT+F2, change the period - From: 1-4-2008 to 30-9-2008.
The Cash flow statement is displayed as shown:
Change Period by pressing F2: Period and set the period, e.g., 1-4-08 to 30-06-2008.
Select the option Auto Column from the button bar.
You can also select Quarterly (or Monthly or any other period) from the list
Columnar Cash Flow Statement
'Cash Flow in Tally.ERP' has been shared with
