Go to Gateway of Tally > F12:Configure > General
Show tables with Masters only in Current Language: If this option is set to Yes, Tally.ERP 9 displays the Pre-defined and User defined Masters in the Language selected. If this option is set to No, Tally.ERP 9 displays the Pre-defined and User defined Masters in English and in the selected Language, along with Aliases created in other languages, if any.
Note: All other options on the screen are explained in F12:Configuration.
Create your company in any language. The Company Creation screen, if Hindi is selected as your language, displays as shown.
Note: The Name of the Company, Unit of Measure and Currency are not translated or transliterated, but displayed in the language in which they are created.
'Enabling Multilingual Support' has been shared with
