https://help.tallysolutions.com/docs/te9rel49/Job_Work/JI_Job_Work_Analysis_Issue_Variance.htm
Issue Variance
Issue Variance report displays the details of variance in the Finished Goods/Co-Product/By-Product/ Scrap delivered against the ordered Quantity of the Job Work In Order. Report also displays the variance Quantity and the Percentage of variance.
To view the stock Issue Variance report
Go to Gateway of Tally > Display > Job Work In Reports > Job Work Analysis > Issue Variance
