From Tally.ERP 9 onwards, Direct Client and Direct Server capability for Synchronisation through private network (also referred as IP Sync) is a default feature available in the product. The process for Data Synchronisation remains the same while doing the Sync using Direct – Client and Server capability (or IP Sync).
The steps for IP Sync are as follows:
Configure Server for Synchronisation
Configure Client for Synchronisation
Create Sync Rule on Client
Activate Rule from Client
Activate/Enable Sync Rule on Server
Synchronise
'Direct/IP Sync' has been shared with
