To import the data follow the steps shown on the synchronisation server:
From the Gateway of Tally > Import Data > Synchronisation > Import Snapshot
The Import Snapshot for selected Rule screen appears
Select the required rule form the List of Server Rules displayed
Enter the required path and filename in Import File Name (XML)
A message Importing snapshot of XXXXXXXXXXXXXXX appears in the calculator pane.
'Import Snapshot' has been shared with
