The Job Costing feature in Tally.ERP 9 is used to track all the incomes and expenses for a project. Each project or job is created as a Cost Centre. The Cost Centres and Inventory Options (Maintain Multiple Godowns) are integrated in Tally.ERP 9 to enable Job Costing, if the company maintains Accounts with Inventory features. For companies that maintain Accounts Only, the Job Costing feature will not be available.
Go to Gateway of Tally > F11: Company Features ( F1: Accounting features)
Set Maintain Cost Centres and Use Cost Centre for Job Costing to Yes.
Set Maintain Multiple Godowns to Yes in F11: Company Features (F2: Inventory Features).
Click Accept to save.
Note: For companies, that Maintain Accounts only, the Job Costing feature will not be available.
'Enabling Job Costing in Tally.ERP' has been shared with
