Tally.ERP 9 comprises of the following salient features:
Simple and easy to use.
Provides concurrent multilingual support.
Allows dynamic selection of the scripts.
Supports flexible data input in the language of the user’s choice.
Easy to use keyboards layouts – inscript as well as phonetic.
Captures language specific aliases for all masters.
Supports user interface in about 10 languages.
Provides the facility to switch to multilingual user interface quickly.
Allows effortless transliteration from one Indian language to another within the Indic family of languages.
Supports translation of masters based on predefined aliases.
In-built dictionaries provide appropriate language conversion during runtime.
Supports Discrete and Combinatorial type uni-directional scripts.
Enables comprehensive localised accounting and financial reporting.
Allows you to display and print bills, vouchers, invoices, receipts, reports and ledgers in the language of your choice.
Generates MIS reports such as confirmation letters, reminder letters in multiple languages.
Allows you to cut or copy multilingual text from other applications such as Microsoft Word, WordPad, Instant Messenger, Outlook Express. Press Ctrl+C to copy and Ctrl+Alt+V to paste in Tally.ERP 9.
'Features of Tally.ERP Multilingual' has been shared with
