Work in Educational Mode is an option available in the Startup screen to the future users of Tally.ERP 9. The future users can install and have live experience on the features and reports available in Tally.ERP 9, whereas Tally.NET User and Tally.NET Auditor can login from a remote location, view reports or scrutinise data while Tally.ERP 9 works in Educational mode.
In the Startup screen
Press Alt+W or select Work in Educational Mode
The Work in Educational Mode has two options
Silver Edition Mode: On selecting this option Tally.ERP 9 will function as Single User edition in Educational Mode. You will be able input data on the first and the last day of the month.
Gold Edition Mode: On selecting this option Tally.ERP 9 will function in Multi User edition in Educational mode. You will be able input data on the first and the last day of the month.
You can select the required option and explore the available features.
'Work in Educational Mode' has been shared with
