To view the list of TCS Output Tax Vouchers which are altered by the Client after Audit,
Go to Gateway of Tally > Audit & Compliance > 44AB Audit
Highlight the numbers in the To be re-audited column for Tax Collected at Source and press Enter
Highlight the numbers for Output Tax Vouchers
The above screen list down the TCS payable Vouchers which are altered after the Audit. For detailed information on the above screen and button options refer to, TCS Bills section.
To Audit the Altered TCS Output Tax Vouchers, refer to Auditing TCS Payable Vouchers.
'TCS Output Tax Vouchers (Altered after Audit)' has been shared with
