Excise Stock CENVAT Register displays the CENVAT details of goods purchased. Using this report the importer of excisable goods can ascertain the pending quantity and CENVAT duty per unit which can be passed on to the subsequent buyers.
To view Excise Stock CENVAT Register,
Go to Gateway of Tally>Display>Statutory Reports>Excise Reports>Dealer/Importer>Excise Registers>Excise Stock CENVAT Register
Excise Stock CENVAT Register can be viewed for All Items or One Item.
Excise Stock CENVAT Register - All Items
To view Excise Stock CENVAT Register for All Items,
Go to Gateway of Tally > Display > Statutory Reports > Excise Reports >Dealer/Importer > Excise Stock CENVAT Register > All Items
In Select Excise Unit screen, select the Excise Unit in the Name of Excise Unit option. The Excise Stock CENVAT Register appears as shown below:
Go to Gateway of Tally >Display > Statutory Reports >Excise Reports >Dealer/Importer > Excise Stock CENVAT Register >One Item
In Select Excise Unit screen, select the Excise Unit, tariff classification and the excise stock item.
Press Enter to accept and generate the report.
To configure Excise Stock CENVAT Register - All Items\ One Item report, press F12 or click F12: Configure button.
The Configuration screen appears as shown below:
Show Purchases of Excise Stock for: Select the required type of purchase bills - All Bills, Cleared Bills or Pending Bills. Excise Stock CENVAT Register displays details according to the option selected.
Show Supplier Name and Address: Enable this option to view the name and address of the supplier. By default this option is set to No.
Show Nature of Purchase: Enable this option to view the nature of purchase (like Manufacturer, First Stage Dealer etc.)
Show Rate and Assessable Value: Enable this option to view the rate and assessable value of the excise stock
Show Excise Duty Amount: Enable this option to view the total excise duty paid on the excise stock. By default the report will display the Duty per Unit.
'Excise Stock CENVAT Register' has been shared with
