After having changed the layout, you need to create the required masters.
In the Ledger or Group creation screen the Name field appears on right and the cursor movement is from right to left.The Group Name are translated to Arabic and also available in English for convenience.
The Ledger Creation screen appears as shown:
The Item Creation screen appears displaying the Name field appears on right and the cursor movement is from right to left.
The Unit Creation screen appear displaying the Type, Symbol, Formal Name and Number of Decimal Places on the right side.
'Creating Masters in Arabic' has been shared with
