To create an output VAT ledger,
Enter the Name of the ledger, for e.g., Output VAT @ 12% on Goods
In the Under field, select Duties & Taxes from List of Groups
Select the Type of Duty/Tax as VAT
In the VAT/Tax Class field, select the required classification, for e.g., Output VAT @ 12% on Goods
By default Inventory Values are affected is set to No
Set Percentage of Calculation will be set to 12% as per the VAT/Tax Class selected
The Method of Calculation will be automatically set to On VAT Rate
Accept the Output VAT ledger.
'Output VAT Ledger (Philippines)' has been shared with
