https://help.tallysolutions.com/docs/te9rel49/Payroll/employee_breakup_of_pay_head.htm
Employee Breakup of Pay Head
To view the employee-wise breakup of the Computation for the required Pay Head,
Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary
Or
Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary
  • Press Enter on the required Pay Head Type
The user can drill down to a corresponding Employee Voucher from the above report.
Button options in the Employee Breakup of Pay Head
F2: Period
Click on F2: Period or press F2 to change the selected period.
F12: Configure
Click on F12: Configure button or press F12 to Show/Hide the Employee Number.
